Having moved and got the shack all set up as I want it I now have to battle an RFI problem.
Antenna is a long wire (I know
   ) set off against an earth rod, 9:1 Balun and an RF Choke in to the shack.    Now here were go into LPF and 2 way switch though removing those two items makes no difference.  The 897 and 590 display the same problems.   All or some of the USB devices on my Windows PC disconnect and occasionally reconnect but more likely require unplugging and plugging back in again.  Feed is 213 MIL.
 ) set off against an earth rod, 9:1 Balun and an RF Choke in to the shack.    Now here were go into LPF and 2 way switch though removing those two items makes no difference.  The 897 and 590 display the same problems.   All or some of the USB devices on my Windows PC disconnect and occasionally reconnect but more likely require unplugging and plugging back in again.  Feed is 213 MIL.  High Power on 2m has the same problem. That is a Tri-Band Collinear again fed with 213MIL.
No matter what ferrite I add I still have the same problem. Only seems to affect 12/11/10/2m. Power doesn't really seem to make that much difference and all voice modes cause the problem, as well as PSK31.
The obvious answer seems to be to sort the KB and Mouse for something better but surely that's not the solution?
 this may or may not help
 this may or may not help  but I hope its useful kind regards Adrian
