List of Chinese handhelds that can be programmed for pmr446
Classic
Post by Classic »
Hi all can everyone add the make and model numbers of Chinese handhelds that can be programmed for pmr446,only add ones that are 100% confirmed to program on pmr446 thanks
UGLY_BOB
Re: List of Chinese handhelds that can be programmed for pmr
Post by UGLY_BOB »
Only got one handheld, and that's my Puxing D03... that does PMR 446. (came programmed 443 though).
Ugs
EXTREMELY WEIRD... AVOID AT ALL COSTS !
fez
Post by fez »
ones that do 6.25khz step.
AndyK
Post by AndyK »
I use PX777s on PMR, the only thing you have to watch is that if you use them alongside "ordinary" PMR sets, the PX777 has 50 CTCSS tones and the numbers do not correspond with the 36 on a standard set. They do provide a list of the tones available on the set so you can work out a conversion chart!
"...invisible airwaves crackle with life...."
Out of the ashes of todays chaos, rises Phoenix like, tomorrows total **** up
26FRS004
GRE PSR295, Intek MT5050, Puxing PX777
Scanning in Lincoln and Leadenham
friendly1uk
Post by friendly1uk »
I have been using a uv3r to listen on. It's overkill though, and not in the right areas. What it actually needs to do it's not great at.
edit: overkill for 446 as its a duel band set, and poor as the channel number is absolutly tiny and the channel change becomes the volume through a menu system. It's not instantly available for tweeking the volume. It's Channel change instead. Moving between environments of differing volumes is not as easy as it could be. Nor is turning it down quickly to save embarisment lol
FakeJake
Call Sign: 2E0SEY
Post by FakeJake »
The Baofeng UV-5R, and the UV-3R too i believe.
Jake 2E0SEY
Saltney, near Chester (Cheshire-Flintshire border)
Monitoring 2m simplex (when I can)
Dysgwr Cymraeg
alannah
Post by alannah »
Chinese radios that I own that work on 446 are:
Wouxun KG-UVD1P
Wouxun KG-669
Linton LT-3288
radiosification
Post by radiosification »
TYT UVF1
